LT4 push rods part#
Old Mar 25, 2004 | 08:43 PM
hozb817's Avatar
LT4 push rods part#
I am looking for the part # for the LT4 push rods. I plan on doing 1.6RR's, LT4 valve springs, I might as well do the LT4 push rods. Thanx for the help..!!
Old Mar 25, 2004 | 09:41 PM
rskrause's Avatar
Moderator
Re: LT4 push rods part#
AFAIK there is not an LT4 specific pushrod. Not sure though.
Rich Krause
Old Mar 25, 2004 | 09:45 PM
hozb817's Avatar
shouldn't there be a specific GM part # for the LT4 push rods?
I believe every GM part has a part #.
Old Mar 25, 2004 | 09:46 PM
rskrause's Avatar
Moderator
What I was trying to say is that they are the same as LT1 pushrods.
Rich Krause
Old Mar 25, 2004 | 10:13 PM
hozb817's Avatar
OK I wasn't sure if the LT4 came with stronger push rods, I thought they came with 1.6RR's. So I just assumed. Could you tell me what kind of push rods I should get to replace my stock ones?? Thanx ~ Jose
Old Mar 25, 2004 | 10:50 PM
97WS6SCharged's Avatar
The stock pushrods are 7.200" length.
Old Mar 26, 2004 | 04:21 AM
rskrause's Avatar
Moderator
I've used Comps for years, though for a mild cam and LT4 springs the stock pushrods would be fine. Anyway, if you get Comps the "High Energy" is the OEM replacement and the "Magnum" is the performance upgrade. The High Energy are really cheap, less than $40 while the Magnum's will run close to $100.
Rich Krause
KamikaZ28
May 28, 2015 12:45 AM
nikolt1
Feb 27, 2015 09:10 PM
ModdedNerd
Feb 5, 2015 04:37 AM
alphaauto
Jan 23, 2015 07:42 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
