LT4/LT1 intake swap
Old May 9, 2003 | 04:29 PM
dansmysticta's Avatar
Question LT4/LT1 intake swap
I was just curious how hard this was to do, and if it was really worth it. I know a guy selling one and was wanting to get peoples thoughts on it. Thanks.
Old May 9, 2003 | 04:44 PM
ChuckZ28's Avatar
You need the LT4 heads to match. Its a different design on the intake runners.
Old May 9, 2003 | 04:50 PM
Talking
Thanks, I really had no idea.
Old May 9, 2003 | 06:24 PM
92LT1RS's Avatar
No you dont. LT4 intake works fine with LT1 heads. LT1 intake does NOT work with LT4 heads.
Old May 9, 2003 | 06:34 PM
elista's Avatar
so which is it what works and what doesn't
Old May 9, 2003 | 10:38 PM
Got-LT1's Avatar
Never heard that before. Anyway, I was told you need to modify the lt4 intake to work with stock heads but I can't be sure.
Old May 10, 2003 | 12:12 PM
92LT1RS's Avatar
It DOES work. The LT4 intake works fine with stock LT1 heads.
Old May 10, 2003 | 12:37 PM
94-3.4's Avatar
Your not gonna see any gains with it though will you?
Old May 11, 2003 | 04:36 PM
arnie's Avatar
No you don't. LT4 intake works fine with LT1 heads. LT1 intake does NOT work with LT4 heads.
If you are referring to physically bolting up components, you got it backwards! If you are referring to port alignment and size of port opening, the two intakes are (+- 1/32") virtually identical, with the advantage in 'overall' oem cast port opening size (larger) going to the LT(1) intake.
No it don't! Not able to physicaly bolt it up, unless you modify the head mounting surface or the intake casting. I'd like to know how you accomplished this. (unmodified)
Old May 11, 2003 | 04:47 PM
350SS's Avatar
That is how I understood it to. Can anyone else confirm this?
Old May 11, 2003 | 05:02 PM
arnie's Avatar
By confirming, I trust you are referring to those that actually use/have in their possession these components, not comfirmation from those that pass on misinformation without verifying (somehow).
Old May 11, 2003 | 05:47 PM
350SS's Avatar
Yes
Old May 12, 2003 | 02:10 AM
SloCal94's Avatar
I have a pair of afr190's that I purchased on ebay. They came with an lt4 intake that had been cnc ported to match the heads. Both the heads and intake say MORE (aka, More performance) on them. Not sure what would match up stock though. From what I have seen there is really no reason to switch to the lt4 intake besides looks, and there are people powdercoating the lt1 intake.
69z-28
Jan 29, 2016 10:46 PM
jj_burchiel
Mar 5, 2015 07:05 AM
ModdedNerd
Jan 29, 2015 07:23 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Nostang 96z
Sep 14, 2002 08:22 PM
