Lt4 knock sensor
Re: Lt4 knock sensor
I would test if first, both the sensor and the harness:
Courtesy of Shoebox
4th Gen LT1 F-body Tech Articles
You can also do a data log to see what temp the sensor is reporting to the PCM.
https://www.camaroz28.com/forums/com...95-lt1-874306/
The sensor screws into the water pump housing, gets removed with a wrench. DO NO ALLOW COOLANT TO DRIP ON THE OPTISPARK DISTRIBUTOR. You can drain the radiator below the sensor level. Or you can have the new sensor ready to quickly screw in as you pull the old one out - not easy in tight quarters, but doable.
Courtesy of Shoebox
Courtesy of Shoebox
Courtesy of Shoebox
