LT4 knock sensor
Old Feb 11, 2009 | 01:40 PM
LT1CJ's Avatar
LT4 knock sensor
Dumb question !
Can a LT4 knock sensor be used in an OBD1 1993 LT1 ?
Old Feb 11, 2009 | 03:05 PM
MTBSully's Avatar
Yes
Old Feb 11, 2009 | 03:35 PM
Stl94LT1's Avatar
No, the LT4 (OBDII) knock sensors can only be used in the OBDII cars. You also can't use the LT4 knock module in your 93.
Old Feb 11, 2009 | 06:31 PM
Originally Posted by MTBSully
Yes
If there were such a thing as an LT4 knock sensor, the answer would still be absolutely not.
Old Feb 11, 2009 | 06:37 PM
6SpdLT1Z's Avatar
and ditto on post #3.
Old Feb 11, 2009 | 07:32 PM
Stl94LT1's Avatar
What part of the #3 post is incorrect? The LT4 used OBDII knock sensors.
Old Feb 11, 2009 | 08:55 PM
6SpdLT1Z's Avatar
Ditto: repeat an action or statement; "The next speaker dittoed her argument"
Old Feb 11, 2009 | 09:21 PM
Stl94LT1's Avatar
Oops sorry, it's been a long day.
Old Feb 11, 2009 | 11:04 PM
MikeGyver's Avatar
Do you mean knock MODULE? I think the sensors are all the same...
Old Feb 11, 2009 | 11:07 PM
There are two different knock sensors.... low impedance for OBD-I and high impedance for OBD-II. But to be technically correct, there is no "unique" knock sensor used in the LT4.... its just an OBD-II sensor, used on all other OBD-II LTx's.
Pretty sure he meant knock module, and not the knock sensor.
Old Feb 12, 2009 | 02:05 AM
a walker's Avatar
I'd also like to add that the LT4 knock module doesn't only work on OBDII cars. They also work on 94/95 OBDI cars as well. The module is not able to be replaced in 93 cars.
mightymouse383
Jul 20, 2016 07:34 AM
4586
Mar 18, 2015 06:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
dreamer1q
Aug 20, 2002 11:19 AM
NJ SPEEDER
Jul 19, 2002 10:22 PM
