LT4 knock module? Where to get one?
Old Mar 1, 2004 | 07:55 PM
"White Knight"'s Avatar
Where can i get an LT4 knock module at? Can i just get one from GM? how much do they run? I hear you just pop them in the PCM inplace of the other one?
Any info on these would be appretiated. I hear it can make a difference?
AxeGrinder30thZ's Avatar
Need to do a search. The topic has been discussed MANY times.
Old Mar 1, 2004 | 07:58 PM
I think i found my own answer.
One (1)LT4 Knock Module (GM Part # 16214681). This will run you about $28.
Old Mar 1, 2004 | 07:59 PM
fstenuf's Avatar
I got mine off of ebay for $45 shipped or so. It takes about 15 min to put in just make sure to disconnect the battery then you just unscrew your PCM and on the tope there is a plate that has 2 hex bolts take these off and yank the box that is in there and put the LT4 KM in. Leave your battery diconnected for about 15 min and then put back together.
Old Mar 1, 2004 | 11:37 PM
JJ's95B4C's Avatar
Do a search for Jason Cromer. He's leaving where he's at now, but if you call soon, you can get it before he leaves.
Old Mar 1, 2004 | 11:54 PM
madhatter's Avatar
Jason or Dal can hook ya up. Or like was said before, you can pick em up off of ebay for $45 shipped.
Installation requires unbolting of the 2 bolts that hold down the PCM( 10 mm), and removing the plate on the back of the PCM that is held by 2 torx screws. Pop out the old, in with the new.
Old Mar 2, 2004 | 03:20 PM
aaron_depue's Avatar
eBay... definetly eBay. I will be the cheapest around. Oh and www.yearone.com also has them
Old Mar 2, 2004 | 03:22 PM
chesee48's Avatar
wheres jason going?
but yea ebay might be the faster/cheapest method IMO...
Old Mar 2, 2004 | 03:53 PM
camarocrayz's Avatar
Get it from me!!!
Old Mar 2, 2004 | 04:11 PM
MonoxideChild's Avatar
gmpartsdirect.com
part# 16214681
Non-NC Residents Total:
$36.87
shipped.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
