LT4 knock module? Where to get one?
Where can i get an LT4 knock module at? Can i just get one from GM? how much do they run? I hear you just pop them in the PCM inplace of the other one?
Any info on these would be appretiated. I hear it can make a difference?
I got mine off of ebay for $45 shipped or so. It takes about 15 min to put in just make sure to disconnect the battery then you just unscrew your PCM and on the tope there is a plate that has 2 hex bolts take these off and yank the box that is in there and put the LT4 KM in. Leave your battery diconnected for about 15 min and then put back together.
Jason or Dal can hook ya up. Or like was said before, you can pick em up off of ebay for $45 shipped.
Installation requires unbolting of the 2 bolts that hold down the PCM( 10 mm), and removing the plate on the back of the PCM that is held by 2 torx screws. Pop out the old, in with the new.
eBay... definetly eBay. I will be the cheapest around. Oh and www.yearone.com also has them
