lt4 knock module
lt4 knock module
I just purchased a lt4 knock module, yet i am concerned that if i put it in, it could do damage to my car. How does it ingnore the "knock" in the lt4 and how EXACLTY does it work compared to the lt1 module. Thanks for your help. Nate
The LT4 motor was equipped with roller rockers which supposedly is more noisy than regular rockers....the LT4 KM is designed to "listen" so to speak for loud valvetrain noise or loud exaust noise, such as headers flowing and not to retard the timing under those conditions, the Lt1 KM will retard timing if the slightest bit of knock is heard.
Originally posted by TMDZ28
i'm planning to purchase one my self, and yet i dont understand how it works
Originally posted by jpolz
Think of it as a "smarter" knock module. It's better able to figure out what is true knock and what is just "engine noise" (Loud exhaust, loud valvetrain, loud stereo, etc...) You don't really gain any HP from it, it's just you won't pull timing at higher RPMs, when you engine is making the most noise.
the lt4 kn is not as sensitive as the lt1 kn. which means that it will not pick up false knock if you have roller rockers. if you are picking up false nock then that retards the timing and you lose horsepower.
The exhaust on my car is extremely loud. Can the lt1 kn pick up false knock from a loud exhaust sytem? Would the lt4 kn fix this? I haven't seen any lt4 kn's sold on any sites, where could i get one for cheap?
Should take you about 5 minutes to put in the KM.
1) Unhook battery.
2) Remove two 10mm bolts holding PCM.
3) Pull PCM out of hole.
4) Remove two bolts holding KM cover on side of PCM and remove cover.
5) Push in side clips on the KM and pull out.
6) Push in new LT4 KM until it clips in.
7) Reverse procedure.
1) Unhook battery.
Nope
Originally posted by Joe Gee
Can you get an LT4 knock module for a 93? I know the computers are different.
Joe
Joe
uh uh...i have one more question...can i install this by my self?? thanks
http://www.projecttransam.com/projects1.asp
To back up SStupid, 1993s do not have the replaceable knock module.
Re: Nope
Originally posted by SStupid
Nope. There is no Knock Module on your '93. If I'm wrong, I apologize, but I'm about 90% certain.
