LT4 knock module?
Old Jun 15, 2009 | 04:02 PM
harrington333's Avatar
LT4 knock module?
Hi everyone! I have a question about if i should install a LT4 knock module or is it something else. The scanner reads 15 for the knock at idiel and should be reading 0 right? I just installed a new knock sensor. The only mods i have are headers,exuast,cold air intake and a mail order tune from PCM For Less. Thanks can anyone help?
Old Jun 15, 2009 | 06:55 PM
slowride94z's Avatar
most use the lt4 km for roller rockers as they are loud, or rattle
Iv read if pipes bump or exhaust leaks, can set off counts
do you run 93+ gas?? it is a must with a tune
good luck, I dont have a lt4 km
Old Jun 15, 2009 | 07:15 PM
MikeGyver's Avatar
Might be some sort of limp mode. Is it throwing any trouble codes?
Old Jun 15, 2009 | 08:08 PM
Knock counts are cumulative. Are you reading counts or knock retard when you say "the scanner reads 15".
Old Jun 15, 2009 | 08:15 PM
LT4 knock module
Hi there. I will check for exaust leaks. Do u mean 93+ octane at the pump....we have 94 here. I will start using it. Yes it did throw a code, It said the right O2 sensor was burning to lean so we replaced it. Thanks.
Old Jun 15, 2009 | 11:08 PM
f you are getting 15-deg of kinock retard at idle, there's a good chance the knock sensor circuit is screwed up, and the PCM is retarding timing to protect the engine. Did the new knock sensor correct the problem? If not, are you sure you have the correct knock sensor - there's one for 93-95, and a different one for 96-97. Have you rechecked the codes AFTER you replaced the knock sensor?
But you haven't told us what year your car is. If its a 93, you can't use the LT4 knock module.
Why not add a "Signature" with basic info about your car - year, model, engine, tranny and any major mods? That way, the info will be added to every post, and people can help you without asking a lot of questions.
Old Jun 23, 2009 | 04:15 PM
Thanks for the help i'll check it out.
Old Jun 23, 2009 | 05:34 PM
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
SergheiS
Sep 29, 2015 08:56 PM
SEOJustin
Sep 24, 2015 04:39 PM
