LT4 knock module
Old Jul 19, 2005 | 11:20 AM
tfs95z28's Avatar
LT4 knock module
How do you know if you need it/what is it for? And what are the benefits of it?
I see it a lot on here in people's signatures and im wondering why so many people run them. Enlighten me all, just wondering if i should get it if it is worth it or not.
Old Jul 19, 2005 | 11:31 AM
Re: LT4 knock module
An informative link... just ignore the source of the part, since the guy who used to give big discounts at Lambert is no longer there.
http://www.projecttransam.com/projects1.asp
Old Jul 19, 2005 | 01:10 PM
tfs95z28's Avatar
Thanks a lot, never really knew why people did it. So is it worth it with my mods? He does say that if you are N/A and run 93 octane that you SHOULDN'T have knock... Is that true? I do have pretty loud exhaust and valvetrain noise is louder as well with the 1.6 rr and cam kit.
Old Jul 19, 2005 | 04:36 PM
If you have encountered false knock (verified by a scan tool), then you may benefit.
Old Jul 19, 2005 | 04:47 PM
Formula_driva's Avatar
you should definately run an LT4 KM
Old Jul 19, 2005 | 05:30 PM
RedRyder518's Avatar
I have an actron super scanner. Would that possibly tell me how much knock retard I am getting? I know that it shows "Ignition Timing Advance (Spark advance to add from base engine timing)" but does that really tell me how much knock retard I am getting?
Old Jul 19, 2005 | 06:25 PM
always faster's Avatar
Does the part :16214681 still good? Because i want to order one at my dealer here in canada
Old Jul 19, 2005 | 06:32 PM
You should be able to monitor actual occurence of knock counts with a scanner.
Old Jul 19, 2005 | 06:36 PM
Buttercup's Avatar
Back when I didn't know anything and went with the flow I installed one. I had false knock problems with the LT4 KM. I was even getting crazy knock counts at idle. Live and learn
I would only try an LT4 KM after you've verified you have a false knock problem. Even then, it may not solve the problem. It might also be worse as it was in my case.
Old Jul 20, 2005 | 08:01 AM
tfs95z28's Avatar
Yeah, i dont have a scanmaster or any scanning tool. Is there a way to find this out without getting one of those things? Like maybe taking it somewhere and they plug my car in and tell me if i have false knock?
Old Jul 20, 2005 | 08:05 AM
Real time monitoring is the only way.
Old Jul 20, 2005 | 11:49 AM
So I take that as a no?
Old Jul 20, 2005 | 12:22 PM
Dave '97 Z28 M6's Avatar
Yep, that's the correct PN.
Old Jul 20, 2005 | 12:32 PM
tfs95z28's Avatar
Damn, wish i knew someone who had a scanmaster... or some other way to monitor that.
Old Jul 20, 2005 | 04:40 PM
that makes absolutely no sense
