LT4 Knock Module for 1993?
Old Aug 25, 2005 | 09:47 PM
Jazsun's Avatar
Can you replace the Knock Module on a 1993? Since the 1993's knock Module is built into the PCM? Would 1.6rr's and LT4 springs set off the LT1 KM? How much does it cost to send my ECM in and get it de-sensitized.
Old Aug 25, 2005 | 10:05 PM
Re: LT4 Knock Module for 1993?
The 1993 ECM has no replaceable knock module.
You can find ways to desensitize the knock sensor with resistors. A search will probably find the info for you. I don't have any links to provide.
Old Aug 25, 2005 | 10:07 PM
Jazsun's Avatar
Ok well I guess the 1.6 RR;s are out then, after doing some searches its just too much of a pain in the *** to get the 93 KM and desensitizing it is kinda dangerous I guess since it may not pick up real knock. Anyone?
Old Aug 25, 2005 | 10:08 PM
Jazsun's Avatar
Would loud injectors/headers cause it to pick up knock?
Old Aug 25, 2005 | 10:30 PM
Jazsun's Avatar
Is it anymore dangerous to desensitize the LT1 knock module then it is to replace it w/ an LT4? Arnt they both doing the same thing? Even w/ it desensitized will it still stop itself from blowing up from knock?
Old Aug 25, 2005 | 10:40 PM
Dave '97 Z28 M6's Avatar
I don't know about loud injectors, but noise from roller rockers and headers have been known to be picked up and (mis-)interpretted as knock (i.e. "false knock").
The LT4 KM was designed to be less sensitive to false knock (the LT4 engine had RR's), but still maintain all the sensitivity to real knock. The knock module acts somewhat like a filter, analysing signals from the knock sensor(s) (on the block), and passing on to the PCM what it perceives as real knock. The LT4 KM is just supposed to be a better, more discriminating filter.
Old Aug 26, 2005 | 01:32 AM
smoknta's Avatar
I've got a 93TA with a 383 cube LT1 with a cam similar to the CC306 and crane gold RR's. The roller rockers are pretty loud. I've also got long tube headers. I hardly ever see any knock retard. I see a small amount when going WOT during he initial hit, but it is like 1 degree. Not affect anything. I would say put em on and try it. Datalog it and see if you are getting any and go from there.
Old Aug 26, 2005 | 02:40 AM
Originally Posted by smoknta
I've got... ...crane gold RR's. The roller rockers are pretty loud...
Yes they are loud... but they sure look purdy!
Old Aug 26, 2005 | 05:37 PM
Jazsun's Avatar
I actually have the 1.6 RR's that came off an LT4 the GMPP ones.
smoknta
Aug 27, 2015 05:07 PM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
karpetcm
Aug 14, 2015 03:02 PM
whitehooptie
Aug 10, 2015 07:02 AM
HectorM52
Parts Wanted
Aug 8, 2015 08:12 PM
