LT4 Knock Module
Old Sep 13, 2003 | 05:48 PM
SnakeSkinner28's Avatar
LT4 Knock Module
Have any of yall put an LT4 knock module on your cars. I recently tuned the computer a bit, one of the things i did was to have it so its programmed to run on 92+ octane, so that should take some of the knock out. I was wonderin if puttin the module would help more, or if now it wouldnt be that necessary. How have they worked for those of you that have done them, and also, did you retourqe the knock sensor, if so where is it located on the motor. Thanks for the help.
Old Sep 13, 2003 | 05:51 PM
Josh-'04 GTO's Avatar
I'm very happy with the LT4 KM. Filtered out a ton of false knock that I was getting. I don't know how much benefit you'll see, it's more beneficial for cars with headers and bigger cams. It seems those two things produce noises that are often sympathetic to the knock sensor, triggering false knock.
Old Sep 14, 2003 | 12:54 AM
SiDeWaYZz28's Avatar
its located inside the pcm . .bery easy to swap out the kms. . .you will need a 3 in extension on a 10mm socket wrench to get the pcm out
Old Sep 14, 2003 | 01:02 AM
CamaroBoy96Z28's Avatar
Put mine in in about 15 min and taking my time. Probably could of done it in 10 if I had everything I needed right next to me. The LT4 KM made a huge difference, I was clearly losing a ton of power through false knock.
Old Sep 14, 2003 | 01:13 AM
notstock4long's Avatar
What, I thought it was in the block. What are you talking about
Old Sep 14, 2003 | 01:36 AM
GrdLockV6's Avatar
I think the knock sensor is on the lower passenger side of the block. Not 100% sure though, I've never actually bothered to look.
Sideway just got the knock module confused with the knock sensor. The sensor is on the block, while the module is just a little chip inside the PCM.
Old Sep 14, 2003 | 01:43 AM
the knock module is in the pcm ive changed mine but i switched over to the stock one cuss im bout to be installing asupercharger . . and im pretty shure he was asking about the knock module . .
Old Sep 14, 2003 | 01:45 AM
ishe trying to change the knock sensor or the km???
Old Sep 14, 2003 | 01:56 AM
drewstealth's Avatar
There isn't really a need to change the knock sensor. But the knock module is in the pcm. It only takes about 5-10 min to change. Also SIDEWAYZ i noticed you live here in fairfield also. I don't think i have seen your car around though. Also why do you have to change it back to stock for a supercharger?
Old Sep 14, 2003 | 09:20 AM
CamaroGuy22's Avatar
I just got my 1LE Elbow (My current elbow is ripped) and my LT4 Knock Module in the mail the other day from Jason Cromer, great guy, i highly recomend doing business with him
I have a loudmouth and my exhaust is pretty loud. So i figured i could be getting some false knock from it...not sure...but its wroth the 30 bucks i paid for the module.
Old Sep 14, 2003 | 11:04 AM
Yup, its right under the #6 and #8 cyl toward the bottom of the block.
Old Sep 14, 2003 | 11:40 AM
hey you live in fairfield we should meet up check out each others rides
Old Sep 14, 2003 | 11:48 AM
people told me it would be a good idea to put the stck mod
ule back in . .plus the catolog yearone said its not recommended for supercharged or nitrous cars
Old Sep 14, 2003 | 11:50 AM
hey drew where did u get dyno at?? out here??in fairfield??
Old Sep 14, 2003 | 12:17 PM
AustinZ28's Avatar
How do I get ahold of Jason? I need a knock module as well. Thanks -az28
