lt4 kit springs??
Old Feb 17, 2003 | 08:19 PM
GreekZ's Avatar
lt4 kit springs??
are the springs that come in the kit large enough to handle the lift of the lt4 cam???
also what all comes in that kit anyway?? cam, springs, retainers, guideplates what???
Old Feb 17, 2003 | 08:36 PM
Dr.Mudge's Avatar
There are no guideplates, it uses SA rockers for stock 3/8" studs.
The Hotcam kit spring are marginal, they supposedly are the same as LT4 standard springs. Some people, 2 or 3 that I can recall didn't use the springs because they weren't cutting the mustard. If you keep the RPMs reasonable you will probably be all right, most people are. Make sure your installed spring height is correct and check for bind.
Old Feb 17, 2003 | 11:45 PM
GreekZ's Avatar
the rockers that the kit comes with are 3/8 stud? not 7/16?
Old Feb 18, 2003 | 12:17 PM
stik6shift93's Avatar
I've heard of a few people running into float with the lt4 hot cam kit, most are fine but it wouldn't be a bad idea to upgrade the springs. It wouldn't cost that much since you'll be able to sell the springs that come with the kit to offset it.
Old Feb 18, 2003 | 12:38 PM
gb95zconv's Avatar
If you plan on spinning higher than 6200rpm ....upgrade, otherwise they will be fine.
Old Feb 18, 2003 | 03:57 PM
Dr.Mudge's Avatar
They use stock 3/8" studs yep, you could always sell them on eBay and go for 7/16" or get some ARP 3/8", you dont need it but I wanted stabilty so I used ARP 7/16" and non SA stuff. Too bad it costs twice as much when your done
LeftoverChinese
Jan 14, 2024 03:03 PM
WildRidez
Jan 16, 2015 03:10 PM
95chwagon
Jan 13, 2015 09:19 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
