LT4 hotcam with stock timing set?
Old Jul 14, 2007 | 07:32 AM
Dudeman41's Avatar
Question LT4 hotcam with stock timing set?
Ok I had my LT1 rebuilt by and engine shop and they put in the LT4 hotcam kit. They put in a new stock timing set. It has some slack in the chain, but I have heard that is usually normal for a stock timing set. My question is will I be ok using the stock timing set with the LT4 hotcam kit? I know there are alot of posts on here about timing chains but I am just a little confused about what I should do.
I am trying to save some money. I have read the best thing to do is to get a cloyes double roller or something similar, new timing cover, and a vented opti, and an electric water pump, but I just really dont want to spend that much money.
BTW my car is a 94 Z28.
Old Jul 14, 2007 | 07:43 AM
f1camaro's Avatar
Well if it is a new stock timing set then it will be fine.
Old Jul 14, 2007 | 07:45 AM
Dudeman41's Avatar
Thanks for the quick response.
Old Jul 14, 2007 | 07:54 AM
ABA383's Avatar
A lot of folks under estimate the stock timing set...I still use a stock set and its been fine...I did put in a new stock chain in 2005 when we did some head work and changed cams, but that was only preventative maintainance...It hasn't broken or had any problems for 12 years...
--Alan
Old Jul 14, 2007 | 01:15 PM
2000GTP's Avatar
The stock timing set will be just fine for the Hotcam.
Old Jul 14, 2007 | 01:34 PM
Executioner2k5's Avatar
im about to install a HC into my LT1 will it be ok to re use my Stock timing set i cant remember if i changed it when i had the motor rebuilt if i did it has 14k if i did it has 66k
Old Jul 15, 2007 | 08:38 AM
96capricemgr's Avatar
I would throw a new chain on it. The new chain only is about $20 from good parts sources.
CamaroHeed
Mar 18, 2020 09:50 PM
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jlo
Feb 3, 2015 09:41 PM
