LT4 hotcam kit installed, and problems after
I know ASE certified mechanics that I wouldn't let change my oil. All that means is that you can take and pass a test. Congratulations. If you want to flaunt that then why are you asking for help for something as simple as engine removal?
Basically your heart is in the right place. It's cool you are on fire for tech type stuff, but you need not take everything you read or hear as gospel truth. Get some experience under your belt and you'll see what I mean. I have a 1993-96 F-body Haynes manual that states to apply sealant around the waterjackets of the intake. How foolish would I have been to get on here and preach that to be the truth and call people "u r dumb/young and dumb..." who didn't believe it?
Now... for the other matter... roller lifters/roller cams do not need to be "broken in". This is quite a shocker, but roller valvetrain components can be switched around as well as long as the valvetrain is healthy are there are not premature wear patterns anywhere.
Basically the only thing that needs to be "broken in" on a modern roller valvetrain engine are bearings and rings.
well just for kicks and giggles, i tried some 20W-50 VR1 racing oil, it brought it up to 10 psi hot idle (40 psi cold idle), 30 cruising, 40-50 about 4-5000 rpms. These were from a mechanical gauge. I know i probably atleast wore a bearing a little, but theres still no main or rod knock, just some lifter noise, so im gonna pull the intake this weekend and see whats going on. What do you guys think?
Pull the motor before you do any real damage. Something is wrong and when it goes out later it's going to cost more money. Nip it in the *** right now.
Did you take your time with the cam install?
ok i let it idle a little and pured some oil over the rockers but after a few minutes there was some oil seeping out of the pushrods so its ok, noise is gone (the RRs were hitting the VC's, fixed now) the valvetrain is nice and quiet. Still have 10psi hot idle with 20W50 VR1 racing oil, 30 spi at 2000 rpms, 40 at 3000. The psi at cruising looks fine to me, still not what it was before, but its just that idle psi with 20W50 that i don't like. No unusual noises. Anybody????? Bueller??? Bueller???
CamaroHeed
Mar 18, 2020 09:50 PM
Wilson
Jul 21, 2002 05:08 PM
