LT4 Hotcam kit
Old Jun 14, 2004 | 12:35 AM
MeanZ687's Avatar
LT4 Hotcam kit
Is the LT4 hotcam kit worth getting and how much hp gains can i get out of it also a sound clip would be nice thanks
Old Jun 14, 2004 | 01:11 AM
Cahill93Z's Avatar
my buddie did the complete kit in his '95 TA which wasn't a very good running car
prior to cam - Hooker long tubes, intake, open y-pipe, 2.73 rear, and DR's - 13.8@100
Cam & new 3.42 rear - 12.9@107 so he picked up a lot but i'm sure others have had better times, it sounds damn good to
Old Jun 14, 2004 | 12:57 PM
MeanZ687's Avatar
thats pretty sweet that plans to be my next mod after the jet hots
Old Jun 14, 2004 | 01:01 PM
a mean 94z's Avatar
I believe I might go with the Hotcam too. I wanted something like the cc306 but I just don't have the money for the heads and other little things.
Seems like you get some pretty good gains outta the cam though...sounds like a great bang for the buck
Old Jun 14, 2004 | 01:58 PM
izzyz28's Avatar
I would say go for it. I put the hotcam kit in when I did my motor and it made a huge improvement. The car feels so much stronger in the upper/mid RPM range, though it did lose a little low end. Not much, just a little. I shift at 5800-6000 RPM now, compared to 5200-5400 RPM on the stock cam. My 1/8 mi. trap speed improved about 2-3 MPH. Numbers aside, the idle sounds great and it runs awesome. I drive my car 25,000+ miles per year, and it has always been stone reliable, no matter the driving conditions. IMO, for the price you can't beat it.
Old Jun 14, 2004 | 02:08 PM
Cahill93Z's Avatar
ya the cam improves top end ALOT my buddy has no problem pulling stock, or near stock LS1's from rolls.
Old Jun 15, 2004 | 01:06 AM
MeanZ687's Avatar
do you always lose low end power with cams and when so is it a lot , do you still have that vicious camaro acceleratioin?
Old Jun 15, 2004 | 01:23 AM
SJBlackZ28's Avatar
I think some people misjudge the hotcam allot. Im doing the LT4 hotcam swap right now plus adding SLP shorties, I would rather go with long tube but im in CALI smog sucks. My buddy had kinda the same setup im doing an the outcome was outstanding power. Well if it loses power in the low or mid or high I got a 100 shot to back it up you should do it bro.
Old Jun 15, 2004 | 01:28 AM
SJBlackZ28's Avatar
one more thing GET HEADERs FIRST for any type of cam
Old Jun 15, 2004 | 01:31 AM
BlackBird97's Avatar
YES!!! GET HEADERS FIRST!!! I just did the hot cam kit to my car, and noticed...minmal...well not what I exspected....types of gains. The exhaust manifolds on the LT1 really limmit the power of the car. Get Headers, Get a Cam...your set!
Old Jun 15, 2004 | 01:36 AM
disco192's Avatar
Some other cams i would look into would be the cc305, XE224/230, and the GM846 (not 847).
cc305 (220 / 230, .510 / .510 114 LSA)
XE 224/230 ( 224 / 230, .502 / .510 112 LSA)
GM846 (222 / 230 .509 / .529 112 LSA)
I like the 846 cam because it has a little more lift than the XE and is ground on a 112 LSA. The 846 is also a crane billet grind. You can get the GM846 from thunderracing for $250 (Part # 40-10HR00014).
All three of these cams will put down more power across the board than the hotcam.
Old Jun 15, 2004 | 01:39 AM
badblackta's Avatar
Hot Cam going in pretty soon. I will let yall know how it goes.
Old Jun 15, 2004 | 05:06 AM
detroit1994z28's Avatar
Hot cam
I just had the hot cam installed in my 94 camaro z28 m6. Its a awesome cam. It sounds mean and makes a nice lope to it. Go to www.exhuastsoundclips.com and click on gm - lt4 hotcam with the loudmouth. - you can hear the hot cam - mike
Old Jun 15, 2004 | 10:42 AM
CMGETSM's Avatar
With stock or mildly ported heads the hotcam kit is a very good buy. I have the kit and like it. I put down 340rwhp with a basic tune from PCMforless. I've since got a better tune from them but my rear end is busted so I'm waiting on a 12 bolt for more numbers. Also the car ran a consistent 13.0@109 w/ 2.0 60 foot. The rearend popping off the line and my driving skills are limiting. I'm an M6.
I am however considering a bigger cam with heavily ported heads as this car is less of a daily driver now.
Old Jul 4, 2004 | 01:27 PM
MeanZ687's Avatar
Can you get the LT4 hotcam kit for the LS1 or just the LT1?
