LT4 hotcam grind number?
Old Mar 11, 2003 | 11:45 PM
Mongoose96's Avatar
Does anyone know the grind number for the LT4 Hotcam? Thanks
Should be a few numbers stamped on the end of the cam
Old Mar 12, 2003 | 12:09 AM
Whitewolf's Avatar
As far as i know the first 3 digits should be consistent with the last 3 of the GM part number 573 I believe but jsut chek it out..the others are like FM and another 3 digit number FM is the maker Federal Mogul prolly and the other are batch numbers and run numbers from the machine shop..hope this helps..take it to a machine shop and see if they can give you some specs if you are still in doubt...hope this helps
Brad
Old Mar 12, 2003 | 11:19 AM
Mongoose96's Avatar
Thanks! 586 is the number
Old Mar 12, 2003 | 11:51 AM
GREGG 97Z's Avatar
What color is your Vette? Is it the blue with white stripe? I wasn't sure if that was the color of all 96 GS's or not. Just curious.
Old Mar 12, 2003 | 11:28 PM
Mongoose96's Avatar
Yes all of them are Blue with a white stripe
HarleyZ28
Oct 5, 2015 06:23 AM
k1996z28
Apr 13, 2015 06:54 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
WildRidez
Jan 16, 2015 03:10 PM
