LT4 Hot cam question
Old Oct 14, 2005 | 04:32 AM
Dansean1's Avatar
In the LT4 Hot Cam kit, the valve springs are rated to .525 lift. But the lift in kit is to .525.
I was under the assumption that one would want to have some leeway, such as valve springs that could for example go to .540 lift, so as to not to take the valve sping to its max each time (they might wear out faster?).
I bought some LT4 valve springs to install with 1.6's, but will probably install an LT4 hot cam as well.
GMPP obviously knows what they are doing.
Any advice, tips, or suggestions on this. Am I alone or making myself understandable?
Daniel
Old Oct 14, 2005 | 06:12 AM
Fastbird93's Avatar
Re: LT4 Hot cam question
I may be wrong, but I believe the valve springs in the LT4 Hotcam kit are "rated" to .550 lift, not .525.
Old Oct 14, 2005 | 08:30 AM
Colin91Z's Avatar
Well, if it helps you confidence in the kit any, I put my hotcam kit in back in 1999, it now has over 100k on it, still runs strong and pulls well to over 6k
Old Oct 14, 2005 | 01:17 PM
clemsb4c's Avatar
I wouldn't worry about it at all the kit was put together buy GM so I'm guessing everything is setup to work perfectly together.
Old Oct 14, 2005 | 02:14 PM
Bersaglieri's Avatar
You'll be fine, the general usually knows what he is doing. There are tons of Hotcam kits out running around, dont worry.
LT4's are rated to .550? I'd like final confirmation on this. Anyone?
-Dustin-
Old Oct 14, 2005 | 04:02 PM
DavesLT1's Avatar
most places I have seen say the LT4 springs are good to .525" lift. but with all the people that run the hotcam kits GM may have rated them conservatively so people wouldn't try to edge by with them into bigger cams.
Old Oct 14, 2005 | 04:05 PM
Dave89IROC's Avatar
what probabaly happened, is the rating is max recommended lift, but no where near coil bind
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
95chwagon
Jan 13, 2015 09:19 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
