LT4 Hot Cam install
Old May 17, 2005 | 09:00 PM
1996z28m6's Avatar
LT4 Hot Cam install
How hard is it to install this cam or any other cam into a 96 z28? Also are thier any documentations for install? Also is there a better cam for the money for street purposes.
Old May 17, 2005 | 09:03 PM
orbitalshock2k's Avatar
Re: LT4 Hot Cam install
Almost everyone with a cam reports that the LT4 hotcam will see minimal power gains over some of the brand name bigger cams that cost the same.
Old May 17, 2005 | 09:28 PM
Z06Z28's Avatar
I'm doing the cc305, search that and also search the xe cams as well.
Old May 17, 2005 | 09:39 PM
tagz's Avatar
I'm with the above statement.. alot of people are sorry when they go with the hot cam and usually wind up upgrading after a while. But that is your choice. As for the install..
Its a matter of removing the intake to take the lifters out, getting the radiator and A/C condensor out of the way to make room to remove and install the cam, and getting the front cover off. You also have to change the valve springs which can be very time consuming. Finally, you set the valve lash. That is an extremely simplified process. Its gunna take you a good 10 hours easy. Plan for 3 days first time around. Take your time, double check everything, then check that again.
Old May 17, 2005 | 11:35 PM
Compstall's Avatar
I'm installing a Hotcam in my car now. I am also taking my time and taking pics and will have a good write-up on it all in my cardomain site in my sig by the end of the week.
Old May 18, 2005 | 12:25 AM
RicocheT's Avatar
Only thing I have to say is keep everything
C L E A N!!!!
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
F(ast)-body
Feb 26, 2003 09:05 AM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
