LT4 Hot Cam install
Re: LT4 Hot Cam install
I'm with the above statement.. alot of people are sorry when they go with the hot cam and usually wind up upgrading after a while. But that is your choice. As for the install..
Its a matter of removing the intake to take the lifters out, getting the radiator and A/C condensor out of the way to make room to remove and install the cam, and getting the front cover off. You also have to change the valve springs which can be very time consuming. Finally, you set the valve lash. That is an extremely simplified process. Its gunna take you a good 10 hours easy. Plan for 3 days first time around. Take your time, double check everything, then check that again.
I'm installing a Hotcam in my car now. I am also taking my time and taking pics and will have a good write-up on it all in my cardomain site in my sig by the end of the week.
F(ast)-body
Feb 26, 2003 09:05 AM
