LT4 Hot cam dyno numbers
Old Feb 27, 2004 | 01:00 AM
JJ's95B4C's Avatar
Please, before you tell me to search, I already have, and haven't come up with many results! Either way, what kind of RWHP can I expect with the mods in my sig and adding a LT4 hot cam kit? Stock heads. I'm guessing atleast 320 with a tune?
Thanks!
Old Feb 27, 2004 | 01:17 AM
97WS6SCharged's Avatar
I'd say 320-330.
Old Feb 27, 2004 | 01:48 PM
JJ's95B4C's Avatar
TTT
Old Feb 27, 2004 | 02:37 PM
stereomandan's Avatar
320-330 rwhp
Dan
Old Feb 27, 2004 | 02:58 PM
GREGG 97Z's Avatar
Mine did 327rwhp/328rwtq when I dynoed it early last year. Same headers as you but uncoated and I've got a few more boltons. Found out I had a bad plug wire causing the breakup in the upper rpm, fixed that and made a couple other changes to the car since that run. Removed the cat and I'm now running an orp/cutout and installed a Walbro fuel pump, the stock one was starting to go. Car is running much better since then, getting it dynod again tomorrow, I'll post the numbers. I'm pretty sure the numbers are going to be better than last time
Old Feb 27, 2004 | 03:01 PM
Originally posted by GREGG 97Z
Mine did 327rwhp/328rwtq when I dynoed it early last year. Same headers as you but uncoated and I've got a few more boltons. Found out I had a bad plug wire causing the breakup in the upper rpm, fixed that and made a couple other changes to the car since that run. Removed the cat and I'm now running an orp/cutout and installed a Walbro fuel pump, the stock one was starting to go. Car is running muchbetter since then, getting it dynod again tomorrow, I'll post the numbers. I'm pretty sure the numbers are going to be better than last time
Looking forward to the dyno results, especially since we are both a '97 M6! Good luck tomorrow. That's still one cam I'm keeping in mind for my cam swap.
Dan
Old Feb 27, 2004 | 03:18 PM
GREGG 97Z's Avatar
Dan
I'll be sure to post them this weekend
djangoroar
Parts Wanted
Feb 21, 2015 11:47 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Burn_Out
Aug 18, 2002 08:49 AM
Smokn '94 Z
Jul 23, 2002 09:24 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
