LT4 Hot Cam with 1.7 Roller Rockers , Valve Spring?
Re: LT4 Hot Cam with 1.7 Roller Rockers , Valve Spring?
The hotcam with 1.7 rockers should give you a lift of .558 / .558.
Acording to CompCams Catalog, the 918s coil bind at 1.085. So with an install height of 1.75 you should be fine. (1.75 - .558 = 1.19)
At 1.19, you'll get a spring pressure around 318 lbs/in. Not sure if this is good for the Hotcam, but I assume it's fine.
Thomas.
Thomas.
As far as springs, the 918 would be good, 1.75 - 1.085 - .06 = .605, that's plenty of lift. Ends up leaving around a tenth of an inch before coil bind.
Originally Posted by flatlander757
What kind of performance increase would a hotcam + 1.7s yield over the stock stuff?
still looking for info on this setup if anyone has it!! would it require clearancing of the valve covers or anything of that nature?
I would also like to know what kind of hp this setup will offer over the standard hotcam setup.
http://www.wku.edu/~nathan.plemons/h..._corvette.html
thank you! I wish he would have given more details about the rockers and springs he used.
oldschool
02-09-2016 09:21 PM
95chwagon
01-13-2015 09:19 PM
