tdc indicator?
Old Sep 16, 2006 | 05:24 PM
93black-ta's Avatar
tdc indicator?
does anyone know of a quality tdc indicator? i need the type that screws into the spark plug hole. i'm not sure my balancer is on correctly.
thanks
Old Sep 17, 2006 | 08:33 AM
Guest47904's Avatar
Guest
Re: tdc indicator?
If your looking for TDC on a piston, with the plug out rotate the engine by hand until you feel air coming out of the plug hole. Then use a wooden dowel or a blunt pencil in the plug hole to indicate when the piston comes up to TDC.
Old Sep 17, 2006 | 08:47 AM
30696bird's Avatar
Re: tdc indicator?
I've used pencils before and they work good but, I like using drinking straws better. They have NO chance of breaking in cylinder and you can feel the piston pretty good. As far as the ballancer goes, the bolt holes are offset........it'll only go on one way.
Old Sep 17, 2006 | 09:42 AM
93black-ta's Avatar
Re: tdc indicator?
yeah, i have a cheap pro products balancer and hub and i just dont trust that thing. i never had a problem adjusting my valves before but now with this thing its a pain.
Old Sep 17, 2006 | 10:21 AM
30696bird's Avatar
Re: tdc indicator?
Adjust them running. Oil won't go everywhere and it's much easier in my opinion.
Old Sep 17, 2006 | 10:49 AM
93black-ta's Avatar
Re: tdc indicator?
I would but im having some other car problems so i cant get them right due to a very erratic idle.
thanks,
9t4lt4z28
Oct 2, 2015 10:28 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
ZXXVIII
Sep 1, 2015 10:13 PM
4586
Aug 18, 2015 07:08 AM
