Lt4 Heads and stock exhaust manifold
Old Nov 18, 2003 | 07:54 PM
JustAnotherGuy's Avatar
Question Lt4 Heads and stock exhaust manifold
Just need to know if the Stock exhaust manifold will mount up the Lt4 Heads.
Just asking cause im not sure if I will have the headers that I want picked out when I do my rebuild.
Thanks for any help.
Old Nov 18, 2003 | 08:01 PM
Seal's Avatar
they should.... lt1 and lt4 have the same stock exhaust manifolds
Old Nov 18, 2003 | 08:25 PM
96z's Avatar
96z
Itll work without a problem.
Old Nov 18, 2003 | 09:19 PM
thanks..
I love you ppl.
I would be so lost without yall
Old Nov 19, 2003 | 09:38 AM
1badasZ's Avatar
can you have the LT1 heads ported to match the LT4 intake?
Old Nov 19, 2003 | 11:15 AM
sssalah's Avatar
I've looked at both heads beside each other and the roof of the LT4 is mush higher, so I doubt it can be done. Also the bolt pattern is different.
Old Nov 19, 2003 | 01:42 PM
96z's Avatar
96z
The bolt pattern is the same on the LT4 intake...
Chris Anderson
Jan 27, 2015 08:30 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
spearous
Jan 12, 2015 11:03 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
