lt4 heads intake onto lt1
Old Apr 21, 2009 | 08:46 PM
Camaro350z28's Avatar
this worth doing? would it free up any ponies on a 94 lt1? its in my 6speed corvette. or should i just wait til i get headers and a cam for the lt4 motor itself? and do complete swap?
Old Apr 21, 2009 | 09:29 PM
Z28Freak86's Avatar
your stock heads are pretty good as they are. It may add a few ponies, but it would be much better to just get the stock one ported. Headers and the heads would be better, but the best would be to have the lt4 heads ported with a custom grind cam (of course that would be with headers on it). Doing that would be the best bang for the buck. without headers on it not it wouldnt be worth the time and hassle to take them off your vette.
Old Apr 21, 2009 | 10:00 PM
ok thanks, cause i have a whole LT4 motor, plus the lt1 inside the car. the lt4 also has roller rockers stock correct?
Old Apr 21, 2009 | 10:52 PM
STOCK, the LT4 heads flow about 15% better than the LT1's. But as noted above, you can gain far more than 15% flow simply by having your LT1 heads ported.
The LT4 engine included Crane Gold 1.6X full roller rockers.
LT1 vs LT4:
http://www.grandsportregistry.com/lt1vslt4.htm
Old Apr 21, 2009 | 11:25 PM
mtperformance's Avatar
LT1 vs LT4:
True but you can open up a LT4 head more than and LT1 head so it depends on where he plans to stop.
Old Apr 22, 2009 | 12:12 AM
Even that's debatable. I have LT4's, and got them with that assumption. But that was in 1999. They were great heads.... in 1999. Today I see ported stock LT1's that outflow my LT4's. I'd think twice before buying a set of LT4's in 2009. There are better choices available if you want more flow than you can possibly get out of an LT1 head.
In any case, he appears to be asking about a stock swap.
Old Apr 22, 2009 | 01:06 AM
ya i was just curious on a swap. i have the lt4 heads and intake already and just wondering since its really not all that much work if its ever worth just swaping them over.
i mean i have the need to work on my car, and im kinda jobless right now so i thought maybe if this can show any gain if its worth it? did the lt4 cam make much of a difference over the lt1? what kinda power gain would i get out of just swappin the heads and intake over? cause all i would really need is some gaskets? i think i can swing that, but im just sayin if its not worth my time and money in gaskets ill just wait. dont have money to port the lt1's
and injuneer.. the lt1 heads ported have more potential than the lt4's ported? i always thought the lt4s had more... hmm interesting.
Old Apr 22, 2009 | 01:17 AM
thanks for that link injuneer. i actually shoulda read that before my other post, it pretty much answered everything for me. looks like i should just wait and spend money on bearings for my lt4 motor, and just do a complete swap. the whole lt4 motor in general is just a nice upgrade from crank to cam and timing chain and pistons.
now.. my lt4 motor i bought from someone due to it having low oil pressure.. they said 10-15 at hot idle.. which isnt that bad itself but.. i am gonna take the motor apart inspect and would like to just freshen it up with new bearings.
while i am in there, is there a cam swap i should do? lt4 cam is improvement over lt1, but the lt4 hotcam.. is that improved over just lt4 cam? is there another cam that can give me a little more power than the hotcam?
Old Apr 22, 2009 | 01:54 AM
henryz28's Avatar
I would go with the CC503.
Old Apr 22, 2009 | 04:07 AM
There seems to be 3 kinds of people out there the ones that say OEM lt1 heads are nasty with the right porting and you will need nothing else, then there are the after market crowd that say Trick flows, AFR, dart, TPIS or however are the way to go with porting and oem's are junk and then the LT4 crowd. So who can say but when I got my LT4 heads and put them next to my stockers the difference is very noticeable and I dont see how any P&P lt1 head would ever out flow a P&P lt4 so who knows.
Camaro350Z28 I went with the CC306 with my LT4 heads (Harland sharpe1.6rr and comp cams beehivee springs ) and Edelbrock LT4 intake because I figured if the cc503 is the best off the shelf cam for a stock LT1 head than a head that has 195cc runners and a 2.0 valve could handle more.
Old Apr 22, 2009 | 05:24 AM
I didn't say that. I said thay once you get to the point where you are chasing the last CFM on an LT1 head, that you might want to look at working a set of aftermarket heads, rather than the LT4 heads.
As far as the differences between the LT1 and LT4 cams, there is very little... the main difference is the 1.6 RR's. Look at the cam specs in the link I gave you. The LT4 cam actually has less intake duration, and less exhaust lobe lift. But it has more exhaust duration, and the same intake lobe lift. The differences are so small that it wouldn't be worth swapping them.
Don't confuse the LT4 cam with the LT4 HOT cam, which is slightly more aggressive than either the LT1 or LT4 cams..... but still not the best choice.
Old Apr 22, 2009 | 08:22 AM
96capricemgr's Avatar
Just to be clear the LT4 intake is internally the same as the LT1 intake, so forget that on LT1 heads.
Far as the LT4s, they are the favorite of bench racers, look around and you wont see that many of them really working that well.
To me the LT4 shortblock is of slightly more interest. The pistons I believe are slighly higher compression. The rods are fractured cap making rebuilding them harder(maybe impossible) but should make them slightly more stable at higher rpms, believe the rod bolts are the same though so would not get carried away. The crank is machined a little different in the fillet and should be stronger, BUT that strength would be lost of it were cut undersized.
It is 4-bolt mains too but that is meaningless when you have stock rods and pistons as you will wounds a rod with those heavy pistons before you wound the mains from rpms.
If I were you I would pull apart the LT4, see how it looks, 10-15psi would not upset me at idle, if it passes inspection you could put fresh bearings in it, a new oil pump relief spring and metal driveshaft($10 for both). Sell the LT4 heads and intake and use the proceeds to buy parts to put the LT1 heads and a better cam on the LT4 shortblock.
I don't think the LT4 shortblock differences would add up to a lot of extra power or reliability but maybe a little bit of both and sounds like you have time and want to play so why not.
Old Apr 22, 2009 | 10:40 AM
injuneer, sorry about that i get what you are saying now about the heads. and cams are not much difference at all. i expected more didnt look at numbers last night.
looks like i will get this lt4 torn down and check it out. gotta wait for tools though, all mine were stolen. waiting on insurance company.
so ya think selling the lt4 intake and heads, and putting it into my lt1 heads, intake, and a cam sounds like the better option? using the bottom end on the lt4. lt4 intake and heads sell for a good amount too if im not mistaken.
how much does porting some lt1's passed the lt4's by a reasonable amount cost? LE and AI were the main two i saw in the past, should i look local or are they still doing it, and decent priced?
Old Apr 22, 2009 | 10:55 AM
I am very happy with AI but to be honest serious port work might be outside your budget if jobless at the moment. I would wait till you can port them right rather than do it halfway.
The LT4 goodies will sell for a bit but not enough to cover head porting and valvetrain.
Just so you know, the real, original LT4 rockers are for a metric stud not the usual 3/8", nothing wrong with that, just have to make sure to use them with the original LT4 studs. They are also a little more lift limited tyhan the version of that rocker Crane sold retail, something like .550-.575 limit seen conflicting reports.
Old Apr 22, 2009 | 02:13 PM
ok sounds like i will hold off then. ill just wait til i can get the lt4 a little fresher and then maybe just do a swap there until im workin again. then i can either build my lt1 or do more work to the lt4. thanks for the help.
