lt4 heads
Old May 26, 2008 | 12:01 AM
lt1stroker's Avatar
lt4 heads
if i have lt4 cams with stock heads, would some elderbrock heads boost my power by over 50 hp?
Old May 26, 2008 | 09:03 AM
96capricemgr's Avatar
The Edelbrock stuff is a joke at best. Their heads and cam package makes less at the flywheels than many ported stock heads setups make at the wheels.
Old May 26, 2008 | 09:18 AM
Your screen name indicates you have a "stroker"..... how big? The LT4 HOT cam (hopefully what you meant when you typed "LT4 cams") and stock LT1 heads are really holding it back. You need a much more aggressive cam and some healthy breathing ported stock heads to make the power a stroker should be capable of.
Old May 26, 2008 | 01:36 PM
lt1stroker's Avatar
Yes i do have the hot cam bull...where can i get some ported heads and some top end cams?? I have 383 stroker but im looking to rebuild the bottem bl ock again. i need to know where to start. i seen that otyher thread but it got really confused. im a newbe to camaros and mostly all the engine technical stuff. can someone help me out??
Old May 26, 2008 | 01:54 PM
mpe331lx's Avatar
if i have lt4 cams
When did they build an OHC lt1?
Old May 26, 2008 | 03:26 PM
Kaj's Avatar
Kaj
I think he means high rpm cam (top-end of the power spectrum). Do not buy the edelbrock LT4 heads or cam. Unless you want to waste money and have very little increase in power. I had a friend that bought the Edelbrock LT4 package awhile ago, with heads, intake, cam. Long story short the car was a turd. I don't know a single person that has had "good" results with those heads. Older stuff is a little different, but why spend that much? When ported stockers are above and beyond the crappy edelbrock heads.
Old May 26, 2008 | 09:59 PM
I've noticed several questions you've posted about your engine, and you are always asking about "cams"..... plural. Your LT1 engine only has one cam.
For heads, look at what is available from Lloyd Elliott, Advanced Induction, or one of our Supporting Vendors - Port Masters. They will typically have vaious levels of heads and cam (singular) packages, depending on what power level you want, and how much you want to spend. If you contact them, remember to tell them its a stroker.
Why do you feel the bottom end needs to be rebuilt?
Old May 26, 2008 | 11:16 PM
lt1stroker's Avatar
^ Because i feel that the previous owner didnt stroke it and lied to me. he had papers but any joe could do that. i have my doubts like everyone else. so im planning in the next 6 months to rebuild it. thats why i need some new heads,cam, and the bottem block. but for right now i have to have some new heads and cam.
So back to the heads/cam.
i emailed elliot portworks and told him that i want to go from lt1 to le1. what i know for a fact is that i have a shift kit, 58mm TB, moroso intake. would the le1 heads/cam put me over 400 rwhp???? by the way i have a 96 z28 a4.
Old May 26, 2008 | 11:26 PM
RyanD's Avatar
No, LE3 might though if you have the supporting mods, exhaust, decent rockers, and a nice stall converter.
Old May 27, 2008 | 12:47 AM
lt1stroker's Avatar
well i mean my budget is real tight right now. budget is between 1000-1500. im just looking for decent power. about 400hp+. do you think a 58mm tb would work with this setup from elliot:
Head/cam package will pull from 2,000 to 6,200 RPM and should make *370 – 390 RWHP
with 30 lb. injectors, 52 MM T.B., 1 ¾ LT’s no cats, good tuning, etc. This will have an idle similar to the HotCam, CC 305, etc.The LT1 LE1 heads consist
Stock Valves with Back Out
Crane 10308-1 dbl valve spring, retainer and lock kit
195 CC Intake Port
Milling, Cleaning, Assembly
Flow About 260/180
Ready to bolt on
Is this a good buy just for daily driving with power??
Old May 27, 2008 | 01:39 AM
Counted Out's Avatar
Double check that first. You could be rebuilding up an engine that was just built.
195 CC Intake Port
Flow About 260/180
Ready to bolt on
A bigger throttle body won't hurt anything.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
