Lt4 Heads
Old Apr 28, 2005 | 04:13 PM
EVERESTZ28's Avatar
Lt4 Heads
How much hp am I going to gain in a lt1-lt4 change of heads and lt1 intake ported, I already have a 58mm TB. I’m not intending the complete lt4 kit, maybe tuning if recommended.
Old Apr 28, 2005 | 05:06 PM
BUBBA's Avatar
Re: Lt4 Heads
You need a cam.JMHO
Old Apr 28, 2005 | 05:51 PM
EVERESTZ28's Avatar
Re: Lt4 Heads
Why Can't Keep Stock Cam On Lt4 Heads?
Old Apr 28, 2005 | 05:54 PM
jkipp84's Avatar
Re: Lt4 Heads
Nothing's stopping you from doing that, but man - what a colossal waste of $. For the price of the LT4 heads and intake, you can get an LE1 heads and cam combo that'd blow the doors off an LT1 with bone stock LT4 heads and stock cam set up.
Old Apr 28, 2005 | 06:19 PM
EVERESTZ28's Avatar
Re: Lt4 Heads
OOOOO, The reason it's that i want a head that works on my near stroke, but i dont wanto to buy a LE3 package and later need change the heads, because Loyd told me that a stroke it's better if starts on a set of LT4.
but if i can gain some hp now instaling the heads..........
Old Apr 28, 2005 | 06:37 PM
Zepher's Avatar
Re: Lt4 Heads
Save the money till you get the entire package.
Just use NAAAAZZZZZ for right now to satisfy your power needs. 100shot should be fine.
Old Apr 29, 2005 | 09:30 AM
96capricemgr's Avatar
Re: Lt4 Heads
In a stock motor the cam is the biggest choke, now it was a smaller cam but one of the b-body guys tried ported aluminums with a stock cam and lost power over the stock iron heads. The f-body cam is a tad bigger and guys have reported gains going to ported heads but the ports on the LT4 heads being bigger to get flow as cast are not going to work that well with a stock cam. You MIGHT pick up a little power but will likely lose some at other points in the rpm band, at any rate it will not be worth the effort and cost. As far as tuning it is a great mod on an otherwise stock car. I do not understand why people try to mod the engine without tuning.
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
