Lt4 head gasket bore size
Does anybody know the bore size and volume in cc of the Lt4 head gasket(12551488)? I know the compressed thickness is .043" but in order to compare it to the Felpro 1074 I need the bore or volume. Thanks Ken
Re: Lt4 head gasket bore size
Ken,
Don't lose too much sleep over it. I'd probably just go with 4.100. If you're wrong and it's actually 4.06 then you'll only be off by .011 points in your calculation. You can live with that.
-Mindgame
-Mindgame
