LT4 ED Timing set
Old Aug 8, 2006 | 10:31 PM
Spitfire557's Avatar
LT4 ED Timing set
Is there any way to use the LT4 Extreme Duty timing set, but still keep the non vented timing cover/opti? I dont' feel like buying a new timing cover or opti, so it'd be great if I could utilize what I have. Thanks!
Old Aug 8, 2006 | 10:45 PM
Javier97Z28's Avatar
Moderator
Re: LT4 ED Timing set
No, no way possible at all. The opti is driven by the 93-94 style timing set.
I'd suggest updating to the vented opti setup at this point. More timing chain options. You could go double roller instead of the LT4 and save close to $200 and buy that new opti. Timing cover you can get used for cheap.
Old Aug 8, 2006 | 10:59 PM
Yeah, that's what I figured.
So what all is needed to convert to the vented system? Opti, timing cover, vac. harness, what else?
Thanks!
Old Aug 8, 2006 | 11:01 PM
Moderator
That should do it!
Old Aug 9, 2006 | 07:33 AM
cehan's Avatar
I just picked up a '95 timing cover at the local U-Pull It yard for $6
Old Aug 9, 2006 | 09:15 AM
wicked_95z's Avatar
Not to mention your optis will last longer
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
