lt4 corvette camshaft
Old Aug 20, 2007 | 07:28 PM
  #16
wrd1972's Avatar
I wouldn't give $50 for that cam personally.
Old Aug 20, 2007 | 07:52 PM
  #17
2000GTP's Avatar
Originally Posted by IPISSONFORDS
Thanks for the input guys there is a guy on craigs list selling a LT4 camshaft from a corvette for $200 but I was wondering if I should do it or not.
Considering you can get a brand new LT4 Hotcam or even a Comp grind for around that much, which will make alot more power, I would rethink that choice.
Old Aug 20, 2007 | 09:10 PM
  #18
Compstall's Avatar
Yeah, $200 is way too much. Even half that is too much. Like 2000GTP said, you can get a brand new cam from Comp for ~$239.
....BTW, I JUST searched the word "cam" in the "for sale" section on this site alone and a whole pile of threads came up.
Old Aug 20, 2007 | 11:35 PM
  #19
sbs's Avatar
sbs
The LT4 cam has less lift and a negligible increase in duration over your stock cam. And they go for $25-50 on corvette boards.
Old Aug 20, 2007 | 11:59 PM
  #20
IPISSONFORDS's Avatar
boy I am glad I changed my mind. LOL what a rip off huh.
Old Aug 21, 2007 | 01:20 AM
  #21
96m6lt1's Avatar
CAMSHAFT SPECIFICATIONS ('96 model year)
(LT1 w/1.5:1 Ratio rockers and LT4 w/1.6:1 ratio rockers)
Engine Valve Lift @ .050"(1.3mm) Specification Engine Lobe Lift @ .050"(1.3mm) Specification
LT1 Intake .447"(11.35mm) LT1 Intake .298"(7.57mm)
Exhaust .459"(11.66mm) Exhaust .306"(7.77mm)
LT4 Intake .476"(12.09mm) LT4 Intake .298"(7.57mm)
Exhaust .479"(12.17mm) Exhaust .299"(7.60mm)
Engine Duration @ .050"(1.27mm) Specification Engine Lobe Separation Specification
LT1 Intake 205 deg. LT1 117 deg.
Exhaust 207 deg. LT4 115 deg.
LT4 Intake 203 deg.
Exhaust 210 deg.
personally i would go to a cc305,new springs cause your factory ones are weak anyway,definately a new timing chain!
Old Aug 21, 2007 | 07:14 AM
  #22
kgkern01's Avatar
If you notice the lift numbers for both cams, a set of 1.6 RR on the stock LT1 cam will give you the same lift numbers as the LT4 cam. So other than 2 deg less intake and 3 deg more exh duration, they are the same cam. Oh and a slightly smaller LSA. Not worth the swap even if it were free IMO.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
