LT4 Conversion passed emissions!!
Guy who just bought my truck wanted it inspected before he picked it up. It's a 94 warranty replacement 4 bolt main stock shortblock, LT4 conversion w/ 1 5/8 primary shorties and a 3" catco converter. Self tuned and running pretty good.
I was sweating bullets when the threw the sniffer in, but they said it ran pretty clean.
Can someone help define these numbers for me?
Reading Standard
HC (ppm) - 133 220
CO (%) - 0.14 1.2
CO2 (%) - 13.5
Reading Standard
HC (ppm) - 133 220
CO (%) - 0.14 1.2
CO2 (%) - 13.5
Originally posted by JSK333
Compare them to my stock 111K mile engine:
HC: 17.5ppm (114ppm limit)
CO: 0.05% (0.63% limit)
So, you'd be over the HC limit here in Cincinnati, Ohio, but under the CO.
You have a '95 auto? Apples to oranges here. In addition, he didn't state the year of the truck.
Am I missing something?
Originally posted by arnie
Guy who just bought my truck..
So, comparing LT4 to LT1...
it's a 94 lt1 w/ the lt4 conversion, stuffed it into a 89 ext cab s-10, not that it matters.. has the 4l60-e, trans go shift kit, tci 3500 stall, richmond 3.73s, didn't have to do a rolling test, just idle and 2500 rpm sniffer.
think the reason my hc reading was so high cause i was idling around 750 w/ the hot cam. has a lot of overlap, blowing raw fuel right on through.
preciate all the replies sticking to the topic answering my questions.
Yes, he said the truck had an LT4 conversion in it. My '95 is an M6.
I didn't realize what you meant was he'd be 'over the limit' IF the engine was in a vehicle similar to yours.
Appears we didn't understood each other. I was referring to the emission test specs. Based on your comments, I was under the impression you weren't aware the other vehicle was a truck. Then your comment about it not passing in yur state would be irrelevant, cuz he would not have to pass your test specs, even if he was in your state, being a truck.
sleeperZ96BT
Sep 9, 2015 08:28 AM
tdigger9899
Sep 7, 2015 10:56 AM
