LT4 Conversion for 93
Old Oct 27, 2003 | 08:02 PM
TEG99SS's Avatar
Just wondering if anybody can offer some insight as to what needs to be done to convert a 93 over to LT4? I did a search and only found info on having to change the fuel rails to 94. What else needs to be done?
I am thinking about doing this over the winter and would like some help to get a head start!
Old Oct 27, 2003 | 11:09 PM
ImportsRsloths's Avatar
Can u say get your heads (or a spare set) ported by phil at advanced induction or lloyd elliot (nightrain66) and you'll probable have a good 30 rwhp over stock LT4 heads!!!!!
Old Oct 28, 2003 | 05:34 AM
Fastbird93's Avatar
As far as I know, the fuel rails is it. Everything else is a standard part. Provided the LT4 kit doesn't come with the LT4 ED timing chain. If that was the case, then you'd have to swap out your timing cover for a 95+, opti for a vented opti, cam dowel pin for a longer one, and make one minor mod to a vac line going into the intake. Oh, and the opti harness will plug right in, you just have to cut down the key on the plug.
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
