LT4 composite valve covers not fitting...Need help fast
Old Mar 23, 2008 | 05:00 PM
  #16
The difference in discussion is the normal Corvette LT1 cover and the LT4 cover, both in composite form. It seems the OP clearly shows that he was having trouble with LT1 covers and that the LT4 cover does not have the tabs that were his obstruction.
Old Mar 23, 2008 | 05:33 PM
  #17
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
OK. I'm clear on that now. Thanks. Is the Corvette LT1 cover different than the Camaro LT1 cover? I apologize in advance if that's a stupid question.
Old Mar 23, 2008 | 05:43 PM
  #18
SnakeOiler's Avatar
The Camaro covers are stamped steel, not composite.
Old Mar 25, 2008 | 07:58 AM
  #19
wrd1972's Avatar
One more question guys.
When I cut these "drip tabs" off, do I need to prep the cut surface or leave it alone. Seems oil might soak into the cut areas. I know super glue would soak into the cut area and seal it up.
Any thoughts?
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
ModdedNerd
Jan 29, 2015 07:23 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
