Lt4
Old Aug 20, 2003 | 11:08 PM
87Z's Avatar
87Z
Lt4
One of my friends has an LT1 z28, with ported and polished LT4 heads, an lt4 hot cam, throttle body, cai, different rr's, automatic, 2800rpm converter, 4.10 gears, shift kit, bigger injectors, chip, and all kinds of little stuff. But when I was at the track with him, his best run was around 13.5 He had it dynoed and it only put down 324 rwhp. Is it just me or do those numbers sound off? What should it be running?
Old Aug 20, 2003 | 11:23 PM
jasons93z's Avatar
those sound about right to me, 324rwhp means he has about 385 or so hp at the crank. His times sound slow though.
Old Aug 20, 2003 | 11:40 PM
pennys58's Avatar
Seems low to me. What year is it? Does he not have the LT4 intake...I think he has to. I'm trying to sell a LT4 crate engine with the hot cam, headers, 58mm tb, etc and it put down 370 to the wheels(stock heads) and ran 12's all day in an automatic. Might want to get some headers, TB, and check the tuning. 13.5 is slow for that set up and 324rwhp is also low...to me atleast...especially for the money sunk into it. Those heads should be flowing in the 300's, but if he doesn't have the tb and headers, it could hurt him.
JOHN
Old Aug 20, 2003 | 11:53 PM
87Z's Avatar
87Z
He has the lt4 intake, and bigger throttle body too. I forgot to mention his exhaust, which is long tubes into true duals with no cats. Maybe he just hasnt had a good day at the track. I rode in it once, and that was the most violent acceleration I have ever felt. While we were out, he lined up with a Z06 and had a half a car length from a stop to 100
Old Aug 21, 2003 | 12:02 AM
pennys58's Avatar
Hmmm...I say bad day at the track and the dyno then...if he beat a z06. Was it a mustang dyno or a dynojet? 324rwhp bothers me, because that is a similar set up I am going with...after all the money I spent I would be pissed with 324 hp.
Old Aug 21, 2003 | 12:45 AM
Dave Feerst's Avatar
thats low, either it isnt tuned right or somone really screwed up the head porting, he should be at 350 minimum, and probibly closer to 400. Ive seen cars with just the hotcam and exhaust put down 324
Old Aug 21, 2003 | 10:10 AM
87Z's Avatar
87Z
I can understand the clow track times though, he has alot of traction problems. I forgot his trap speeds, but he was spinning through third and getting a chirp in fourth
Old Aug 21, 2003 | 10:27 AM
wiked95ta's Avatar
Has he done anything to the suspension yet? How about drag radials or et streets? Since traction is an issue, he might want to start with some better suspension/stickier tires
Old Aug 21, 2003 | 11:09 AM
87Z's Avatar
87Z
I Dont know what he has done to the suspension, but he has 275 17 drag radials
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
sleeperZ96BT
Sep 9, 2015 08:28 AM
jackpawt883
Aug 26, 2015 11:22 AM
Cbr02
Parts Wanted
Aug 21, 2015 08:16 AM
