Lt383
Old Nov 24, 2018 | 04:12 PM
Cokesbody's Avatar
Lt383
I’m doing a 383 for a 97 Camaro.my question is what flywheel and balancer is used? Do you still use the 350 flywheel and balancer or do I need to buy ones for the 3.75 crank? In an old school small block you woul have to run a 400 flywheel and balancer for a 383,so just wanna make shur I get rite parts because I just took engine down to machine shop and my machinist wasn’t shur either.let me kno thanks.
Old Nov 24, 2018 | 08:46 PM
JakeRobb's Avatar
Super Moderator
Re: Lt383
The manufacturer of your new crankshaft will have the most reliable information on this.
Old Nov 25, 2018 | 09:31 AM
Re: Lt383
Assuming you are doing an LT1 build, if are using a 1-piece rear main seal crankshaft, you need a flywheel with a specific balance weight to compensate for the missing piece of the end flange on the crank that allows the rear main seal to be installed. The front harmonic damper/pulley (not a “balancer”) is neutral balanced.
See post #4 in this thread:
https://www.camaroz28.com/forums/3rd...6/#post6987414
Old Nov 25, 2018 | 09:42 AM
Cokesbody's Avatar
Re: Lt383
Ok so, it’s lt1 based yes.it a used crank n rods i bought out of another lt383 set up... I was reading up on so other posts,and read that all 86 and up 1 peice cranks are neutral balance in the front and external in the rear,meaning the stock flexplate that’s weighted and the stock pulley should be right for application??? Correct
Old Dec 26, 2018 | 06:05 PM
87Aerocoupe's Avatar
Re: Lt383
You can actually do it either way, when I built my forged 383 I had my machine shop internally balance my rotating assembly and flywheel and I'm using a Fluidampr as well. Or you can leave it factory balanced neutral balanced at the front and external balanced at the rear.
WRuiz
3rd Gen / L98 Engine Tech
Jun 22, 2016 11:05 AM
SSTAT
Sep 25, 2014 01:56 PM
Gio93z
Apr 4, 2010 12:59 AM
hosspwr94
Advanced Tech
12
Jul 23, 2007 08:22 AM
LT1CST
Jan 5, 2007 10:10 AM
