lt1vsls1 bore & stroke
Old Jun 25, 2004 | 02:39 AM
Munson's Avatar
the lt1's bore and stroke is 4.0x3.4 and the ls1's is 3.89x3.622 would their higher stroke have something to do with why they make more hp stock than lt1's?
Old Jun 25, 2004 | 03:18 AM
med_reject's Avatar
more compressoin does = more HP, but these motors also have different heads, different rockers, and probably a lot of other differences.
Old Jun 25, 2004 | 08:08 AM
96capricemgr's Avatar
The only things these two motors share are cylinder count, bore spacing and a Chevy pedigree. The differences are far to great to try to attribute any running characteristic to just one of the differences.
Old Jun 25, 2004 | 02:22 PM
Munson's Avatar
well i know the heads, intake manifold, and ive even heard the exhast manifolds flow better stock.. i was just wonderin how much the stroke had to do with it
Old Jun 25, 2004 | 04:41 PM
LameRandomName's Avatar
And some bearings.
Old Jun 25, 2004 | 05:29 PM
DrivinSidewayz's Avatar
higher horse power is how fast you can spin the engine, the LS1 is at a disadvantage geaometry wise on the bottom end, longer stroke and smaller bore, promoted torque, not high spinning, but the LS1 isnt bad off, and its way effeicient, so it spins high, flows more, and makes more power. but then again you could say the longer stroke, promotes torque, therefor, adding the higher revvs than the LT1, it makes more HP.
Old Jun 25, 2004 | 05:43 PM
Munson's Avatar
very intresting
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
