LT1 year to year
LT1 year to year
well I am going to be installing the hotcam kit, and while aquiring parts I found someone that had a 4 bolt disassembled lt1 from a non vented opti corvette. I was wondering if the intake manifold and heads were the same and will fit okay on my 1995 LT1 all I need to know if the early intake and heads are the same and will work on my T/A. thanks for the help guyz
I am getting the intake manifold painted and don't want to have an intake painted that won't work.
What year is the Vette? The early stuff I believe had a different fuel rail crossover which will not work with your fuel rail.
Heads should be the same and would fit reguardless of wether they are the same casting number or not but most likely are the same number.
The 92 and 93 Corvette and the 93 F-Body intake manifolds do not have slot at the front for the diagonal fuel rail crossover pipe, required for the sequential injection fuel rails. 94 Corvette would match your 95 F-Body as far as the diagonal crossover pipe, but then the fuel supply and return lines would connect on the opposite side from your F-Body.
the extra one I have has the diagnal slot. so all I have to use is my fuel rail from the 95 t/a? the casting numbers on the manifold match on the passenger side of the manifold, telling me that they are the same.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Dec 3, 2014 12:30 PM
jrp4uc
26
Jul 9, 2002 04:37 AM
