lt1 year questions...
Old Feb 22, 2003 | 05:51 PM
Vendor Defendor's Avatar
well i got my friends LT1 that we are going to put in his 88 camaro sitting in my garage right now... what i was wondering is what year the engine is...
the numbers that i have found on it so far, (i havent ripped it apart are)
on the back of the engine... GM 57LG
SGI
and on the passenger side motor mount these numbers are there: 10188334 LT1 RH
any ideas?
here are a couple pics of the engine...
Engine 1
Engine 2
and i finally have a question...
what the hell is this (were studs are sticking out)?!
thanks for any help
neil
Old Feb 22, 2003 | 05:58 PM
Check the timing chain cover vs. the pics in this article:
REBUILDING THE LT1
The hole on the back of the intake, with the two studs is the connection for a tube from #8 exhaust runner, that supplies exhaust for the EGR system.
Old Feb 22, 2003 | 07:20 PM
This will tell you the vintage of the engine.
Old Feb 22, 2003 | 07:25 PM
CODY BEHNKE's Avatar
Those studs by the EGR is where the EGR exhaust tube hooks up.
Old Feb 22, 2003 | 08:15 PM
Blue89Bird's Avatar
does the opti spark have a vent tube? If so it's a 95-97... if not a 92-94.
Old Feb 23, 2003 | 08:25 AM
thanks for the help, but right now i cant really see exactly those numbers engraved by the oil filter, they look like they have been more or less scratched in...
and that EGR exhaust runner is there away to block it off? see the deal is that its going into my friends 88 camaro, and we have to use his factory manifolds for now... (hofully they bolt up)
is there any other problems that we are going to have along the way? hes getting a computer and wiring harness for the car, so hopfully it will just bolt in and hook up...
is there any tricks to getting the distributor and water pumps off that i should know about before i rip them off?
i hope this isnt as hard as im afraid its going to be..
*oh yeah i forgot to say that it has alunium heads.. doesnt that mean its a 95-97?
thanks for the help...
neil
Old Feb 23, 2003 | 08:32 AM
The vin derivative is applied in a dot matrix fashion, so the numbers look a little funny.
This site may help with some of your removal and install questions.
Old Feb 23, 2003 | 09:33 AM
this may sound a little stupid but whats opti spark?
Old Feb 23, 2003 | 10:12 AM
It is the common name used for the front mounted distributor on the LT1 engine. It uses an optical pickup for timing references.
Old Feb 25, 2003 | 09:38 AM
alright thanks its, a 96-97 motor...
thanks again...
neil
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jul 4, 2005 05:00 PM
