LT1 wiring harness
Old Jul 25, 2006 | 05:32 PM
AndyCLT1's Avatar
LT1 wiring harness
I'm adding A/C to my non-A/C Formula M6. Will an LT1 engine wiring harness for an automatic '95 T/A work on an M6 car? Or are there connections on the 6 speed that aren't the same for the auto? Any info would be appreciated.
Thanks,
Andy
Old Jul 25, 2006 | 05:44 PM
madwolf's Avatar
Re: LT1 wiring harness
You would be better off adding just the A/C connector. The harness will work but you will still need to modify it for the VSS connector, reverse lockout, etc.
Old Jul 25, 2006 | 06:26 PM
AndyCLT1's Avatar
How would you add the A/C connector?
Old Jul 25, 2006 | 06:40 PM
Dave89IROC's Avatar
you sure its not there already?
I can't beleive they made a different harness for non-a/c, no one else does
Old Jul 25, 2006 | 07:42 PM
madwolf's Avatar
Yea, I was thinking about that too.
If the connector isn't there, you will need a connector from a different harness and add it to your PCM connectors. Check shbox.com for the pinouts.
Old Jul 25, 2006 | 08:23 PM
Dave89IROC's Avatar
if it is there, it will likely be taped back to the harness, same with the pressure transducer connector
Old Jul 26, 2006 | 08:29 PM
AndyCLT1's Avatar
I don't remember seeing any extra plugs when I had the engine out a couple years ago. I had the harness entirely off the engine. I'll call a dealer and see if there are two different part numbers.
Thanks,
Andy
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
gh0st
Sep 1, 2002 10:24 AM
Teal94V-6
Aug 31, 2002 09:21 PM
Rich_z28
Aug 29, 2002 10:44 PM
