Lt1 waterpump fitting question
Old Mar 10, 2009 | 06:21 AM
Nostang 96z's Avatar
Does anyone know how the 90 degree ~5/8" tubes coming out of the water pump are installed into the water pump? I need to move one as it is getting in the way of a vacuum pump belt. Are these threaded pipe fittings or pressed in? Any help will be appreciated.
Thanks and kind regards,
Matt
Old Mar 10, 2009 | 06:41 AM
They are pressed in. You might be able to twist it to another position and it not leak.
Old Mar 10, 2009 | 07:09 AM
Ah dammit! I figured that would be the case. I will probably try to remove the fitting, thread the water pump and replace it with a pipe thread fitting. Thanks for the quick response! much appreciated.
Old May 15, 2009 | 02:27 PM
Rich2279's Avatar
Did that work? Were you able to install a pipe thread fitting?
Old May 15, 2009 | 09:22 PM
I don't see why not. Other people have.
Old May 15, 2009 | 09:38 PM
Rich2279's Avatar
This is the first I'm hearing of this mod. I didn't realize it was a common thing to do.
Old May 16, 2009 | 07:20 AM
I was able to turn it a little bit with a wooden dowl. Those things are in there really really tight. I have not seen it if it leaked yet but I would guess, no as tight as they are.
Old May 16, 2009 | 08:36 AM
mzgp5x's Avatar
I plugged my WP port with 1/2" npt. I would recommend use of a straight thread npt tap since there are water jackets behind the port (hard to get enough thread with a tapered tap since it is long). I used a small file and drilled the stock fitting out. Those stock fittings are mechanically swaged in the WP. I also run a Vac pump (crank drive). 97ss. B.
Old May 16, 2009 | 11:26 AM
94SLUG's Avatar
Use proper size rachet extension and move where you like...
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
pologreen97z
Dec 2, 2014 10:42 AM
lbrowne
Nov 13, 2011 04:25 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
