Lt1 waterpump fitting question
Does anyone know how the 90 degree ~5/8" tubes coming out of the water pump are installed into the water pump? I need to move one as it is getting in the way of a vacuum pump belt. Are these threaded pipe fittings or pressed in? Any help will be appreciated.
Thanks and kind regards,
Matt
Matt
Ah dammit! I figured that would be the case. I will probably try to remove the fitting, thread the water pump and replace it with a pipe thread fitting. Thanks for the quick response! much appreciated.
I plugged my WP port with 1/2" npt. I would recommend use of a straight thread npt tap since there are water jackets behind the port (hard to get enough thread with a tapered tap since it is long). I used a small file and drilled the stock fitting out. Those stock fittings are mechanically swaged in the WP. I also run a Vac pump (crank drive). 97ss. B.
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
lbrowne
Nov 13, 2011 04:25 PM
Wilson
Jul 21, 2002 05:08 PM
