LT1 Water Problems
Old Nov 26, 2015 | 12:59 PM
TipTricky's Avatar
LT1 Water Problems
So i got the car and when i add water to the radiator it slowly drains out of the oil drain plug. Someone just did head gaskets on it because it started overheating after he bought it. He said there was water in the oil and over heating. Im dropping the motor and trans out of the bottom but do you guys think it has a hole in the block?
Old Nov 27, 2015 | 09:07 AM
Re: LT1 Water Problems
Only tear down will reveal what is actually wrong.
Old Nov 27, 2015 | 04:56 PM
bw_hunter's Avatar
That's true and you can be sure that it isn't a minor problem.....
Old Nov 27, 2015 | 06:16 PM
blac94Z's Avatar
you crack the head before the block
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
SergheiS
Apr 26, 2015 08:15 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Spcquinn
Apr 10, 2015 04:02 PM
FredM
Mar 6, 2015 03:04 PM
