LT1 w/1.6RRs Vs. Stock LT4
I was doing some early morning math when I think I discovered something interesting.
These are the lift numbers I found for the LT1 and LT4.
Valve Lift @ .050"(1.3mm)
LT1 (with 1.5 rockers)
Intake .447"(11.35mm)
Exhaust .459"(11.66mm)
LT4 (with 1.6 rockers)
Intake .476"(12.09mm)
Exhaust .479"(12.17mm)
Assuming that info is correct, then a LT1 cam with 1.6 rockers installed actually has the same lift on the intake side but more lift on the exhuast side then a stock LT4 cam with 1.6 rockers
(based on valvelift/1.5(rocker ratio)=X and X*1.6=new lift numbers.
Effectively making a stock LT1's cam with 1.6 RR's:
.447/1.5=.298 then .298*1.6=0.477 intake lift
.459/1.5=.306 then .306*1.6=0.490 Exhuast lift
I dont know why I found that so interesting, but I was kinda shocked. Granted the LT4 is far from a Hot Cam
LT4 Hotcam
Lift with 1.5 Rockers
Intake .492 in
Exhaust .492 in
Lift with 1.6 Rockers
Intake .525 in
Exhaust .525 in
Just thought I would share that tid bit of info I found. Maybe someone can put it to good use.
LT4 Hotcam
Intake .492 in
Exhaust .492 in
Intake .525 in
Exhaust .525 in
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
