LT1 valve spring question
Old Mar 8, 2009 | 11:17 AM
MichiganSkip's Avatar
It's always entertaining to see what people's thoughts are on engine parts, so I'll pose this question.
Can flat tappet springs be used with a roller cam on a street/strip motor application, assuming the springs can handle the lift without binding, and the springs can handle, and are set up for the spring pressures the cam requires?
ie.... does a roller cam "require" roller springs if flat tappet springs can meet the task..........?
Old Mar 8, 2009 | 10:22 PM
IrocSS85's Avatar
dont think so dude. the roller cams are faster to ramp open, and the springs are beefier. dont think you'd find any flat tappet cams with enough spring press/lift to fit a roller cam.
one question for you, WHY?
Old Mar 9, 2009 | 12:02 AM
MachinistOne's Avatar
Springs are not made as "roller" or "flat tappet" - there are simply springs that set up with a certain spring pressure at a set height, then based off their spring rate get a certain open pressure.
A flat tappet mechanical cam requires spring pressures in the same range as a hydraulic roller, it's just hydraulic flat tappet cams that take lower pressure.
Old Mar 9, 2009 | 06:53 AM
rskrause's Avatar
Moderator
Ditto. The spring has no idea what kind of tappet is down there! I hope you found my post entertaining ;-)
Rich
Old Mar 9, 2009 | 11:15 PM
IrocSS85's Avatar
thats why I was asking him to tell us more info about what he wants to do. ie, he has a pretty aggresive spring in flat tappet terms, that has X press on the seat, and wants to use it on what cam? but yeah I guess if thats your question then they answered it better then I did.
Old Mar 10, 2009 | 03:54 PM
Rich
Very much so, as was the one previous to yours.
Thanks guys
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
