LT1 Tuning Help Needed!!!!
Old Mar 11, 2004 | 10:33 AM
94Camarov6SS's Avatar
I have a 96 Z28 and I just got it. It has these mods installed, Comp Cam 306
Dual Coil Valve Springs/Pushrods
LT4 Lifters
G2 Cold Air Intake
Airfoil
Flowmaster
and I believe the MAF is stock.
The car runs fine but Idle is a little wierd to me and it has a little bit of a bad throttle response. I was thinking with these mods that I should get the RPM's tuned etc. and I'm about to put new plugs and wires and I also though maybe a MSD Ignition would do the job. If anyone has any tips for me or what I should purchase to make it run smoother with these mods plz help. Or if you think the combination of these parts is wrong. I have looked it up and it checks out. The cam has a .510/.540 Lift and you have to run the dual valves etc. I was just wanting some tips thnx.
Old Mar 11, 2004 | 12:19 PM
QUASARBLUEZ28's Avatar
Do you have headers or still stock down there? What about roller rockers? Still stock or after market?
Definitely with that cam, you need to re-program you system.
Might try PCMFORLESS for that or get a dynotune.
Old Mar 11, 2004 | 01:15 PM
Red96Lt1's Avatar
madz28 is good too.
Jrlt1
Jan 3, 2015 07:38 PM
Jazsun
Dec 29, 2014 12:14 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
