LT1 Tuneup
LT1 Tuneup
i've spent the past half hour searching and i'm gettin frustrated. to make a long story short i need opinions on tune-up parts for a 96z:
part (brand i think is good)
Opti (delco thru cromer or the dude in florida)
water pump (gunna go with an electric one any ideas?)
plugs (delco)
wires (9mm of some sort?)
coil (delco)
icm (delco)
o2s (delco)
pcv valve (delco)
fuel filter (delco)
it's not my car but im doing the work on it and i have a bottomless budget on parts so the kid wants the best stuff goin in without being rediculous. any input would be appreciated thanks!
plugs (delco)
coil (delco)
icm (delco)
o2s (delco)
pcv valve (delco)
fuel filter (delco)
Re: LT1 Tuneup
coil (delco)
icm (delco)
For the WP I'd go with CSR and NGK TR55s for plugs or autolite 104's. AC Delco for the O2's and fuel filter
Re: LT1 Tuneup
Change all the fluids as well. With that budget, I would recommend getting the Delteq, also. AC Delco Platinum plugs are great, no need to switch brands IMO... unless the car has certain mods.
Re: LT1 Tuneup
if the trigger system on the opti is bad he will still have to buy a new one anyway...i had taylor 8mm on my car before they got destroyed and i thought they were nice wires, just check the lengths before you put them on
Re: LT1 Tuneup
thanks guys im going to replace the opti anyway so we'll look into a delteq later down the line...i consider that a mod and this car is bone stock we just want to get it running in tip-top shape before messing with it(car went mid-15s at 90mph
granted i wasnt driving but damn)
so after its back to lt1 standards we'll look into modifying it
granted i wasnt driving but damn)so after its back to lt1 standards we'll look into modifying it
Re: LT1 Tuneup
