LT1 total bearing replacement...
Old Oct 30, 2006 | 10:26 AM
wrd1972's Avatar
May be pulling the 78K block out to replace cam bearings for cam install.
Is it possible to replace the rod, main bearings in addition to the cam bearings if the block is out and on a stand?
It would make sense to me to just replace them all in one lick. I have no reason to believe I need a rebuild, dont have the money either. A full set of bearings should do the trick for miles to come.
Old Oct 30, 2006 | 10:59 AM
FryedClutch's Avatar
honestly if your gonna do all that just throw new piston rings in there as well
if the motor is on a stand its easy to do all the bearings and since alll your stuff is still fine
summit sells a complete rering kit for a round 300 with gaskets bareings and all that
you would just need the cam bearings
Old Oct 30, 2006 | 01:28 PM
Javier97Z28's Avatar
Moderator
I wouldn't re-ring w/o honing the cylinders.
Old Oct 30, 2006 | 01:34 PM
Sweetred95ta's Avatar
Use Clevite H series race bearings and replace all the studs and bolts with ARP's.
Old Oct 30, 2006 | 01:49 PM
wrd1972's Avatar
I agree, the cylinder walls look and feel very smooth with no signs of wear. The pistons will not be removed to replace any of the bearings.
The rings will stay and the main bolts will be ugraded.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Dec 4, 2014 11:56 AM
