finally up and running
Old Oct 29, 2006 | 08:33 PM
TransAmGT94's Avatar
After all the problems ive had the beast is finally up and running.
I stuck it on the dyno today knowing that it had a miss and also knowing that my tune was off and the o2s are most likely faulty. I put down 378 to the wheels at 5500 rpm. I was a little scared to take it up to 6500 where i should with all the trouble ive had. I didnt think that was too bad considering the problems i still have left to work out. Im looking for 4 to 425 tuned and hitting on all 8.
The engine end up being a 389 stroker with unported trickflow heads.
Old Oct 29, 2006 | 08:34 PM
ill have to pull up the graphs next time i go over to the shop. I was a little surprised that i was still under 400 foot pounds of torque
Old Oct 29, 2006 | 08:36 PM
MeanGreen97Z's Avatar
Seems you have some more bugs to work out. Nice setup though.
Old Oct 30, 2006 | 02:37 PM
mebanditws6's Avatar
Torque should go up once you have the miss fixed. A dyno tune will also help that out. What's your compression again?
Jason
AlaskaZ28
Jan 1, 2015 12:30 PM
ChrisFrez
Dec 7, 2014 06:01 PM
squarehead
Nov 21, 2014 08:02 PM
guionM
14
Jun 19, 2002 08:30 AM
