LT1 timing chain concerns,
Old Aug 15, 2004 | 08:29 PM
Zepher's Avatar
I was looking at a timing chain gif that Shoebox posted last week and I noticed at #1 @ TDC the timing marks were at 12oclock on both the cam and crank sporckets.
I had #1 cylinder at TDC and installed the timing set with the timing mark on the cam sprocket at 6oclock and the crank sprocket at 12oclock, just like you would do on a normal SBC.
Am I going to have to yank the chain off and re-do it? The oil pan gasket is a pain in the *** to put back on (motor is in the car).
Old Aug 15, 2004 | 11:02 PM
1fastlt1's Avatar
Re: LT1 timing chain concerns,
You're good to go man! Just to make sure I'm thinking about this correctly the dot on the cam gear is at the bottom and the one on the crank gear is at the top
Is this the diagram you are referring too?
Timing Gears
Richard
Old Aug 15, 2004 | 11:09 PM
1racerdude's Avatar
You are good to go,it is correct with the marks "together" so to speak.
Old Aug 16, 2004 | 03:57 AM
Zepher's Avatar
cool, thanks.
The animated gif showed the timing set rotating and showed where the marks were for tdc of each cylinder.
This is the gif I saw,
Old Aug 16, 2004 | 09:37 AM
Tommy'Z 6speed's Avatar
That's because the cam turns 1/2 the speed of the crankshaft.
Therefore, the cam mark will be at 12 o'clock at one point and 6 o'clock one crankshaft revolution later. As the crank turns, they align, they don't align, they align, they don't align...
Old Aug 16, 2004 | 11:35 AM
quicksilver97ta's Avatar
Just put the opti on correctly and it wont make any difference.
Old Aug 16, 2004 | 01:48 PM
jtk's Avatar
jtk
it actualy dosent matter if the dots are pointing twards each other or away, it sure is easyer lining them up when they point twards each other though.
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
