lt1 timing chain
Old Feb 25, 2007 | 07:41 PM
30th6's Avatar
lt1 timing chain
if im runing a electric water pump can i run a sbc timing chain? thanks joe
Old Feb 25, 2007 | 07:44 PM
Z95m6's Avatar
Yes you can, you just need one for a 87+ I believe.
Old Feb 25, 2007 | 07:48 PM
mdacton's Avatar
search... you need to clearance the cover
Old Feb 25, 2007 | 07:51 PM
LenT1's Avatar
I opted to use the cloyes double roller as it is cheap and I hear it is the best. Like mdacton said you need to clearance the cover though.
Old Feb 25, 2007 | 08:07 PM
94/96ZsM6s's Avatar
just find the cloyes 87 and up dual roller and it works jsut fine. Although i never clearenced the cover, the cover fit just fine, its held up just fine for 10k...but do take thier advice and check the clearence...
Old Feb 25, 2007 | 09:50 PM
30th6's Avatar
does anyone have a part #on the cloyes double roller.
Old Feb 25, 2007 | 09:55 PM
mdacton's Avatar
3145
Old Feb 26, 2007 | 01:49 AM
SS RRR's Avatar
Only if it's a double roller.
Old Feb 26, 2007 | 12:36 PM
30th6's Avatar
should i need one with like 45k on the shortblock?im gonna run le2 with a 150 shot.thanks for the input joe
Old Feb 26, 2007 | 01:27 PM
2000GTP's Avatar
With that cam, I would definitely upgrade regardless of the miles.
Old Feb 26, 2007 | 01:50 PM
Z-RATED94's Avatar
Same advice here, with those kind of miles, a new chain and gears would be in order. But it would also be nice if you could check and make sure your cam is degreed in to where it should be. Some have found certain gears and chains to throw off the cam timing.
Old Feb 26, 2007 | 06:00 PM
dren70's Avatar
From: brunswick ohio, small burb south of cleveland
is the stock cam ground straight up?? no advance or retard built in that you need to account for with the chain??
david
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
