Lt1 thirdgen
Old Aug 24, 2009 | 11:07 AM
  #16
red94chicken's Avatar
or your could check your iac.
Old Aug 24, 2009 | 12:37 PM
  #17
SupersportLS1's Avatar
Well the tuned computer comes tomorrow and im by myself today and my car wont stay running at all i assume you have to check it when the car is running ill reasearch some more. Thanks
Old Aug 24, 2009 | 04:30 PM
  #18
Okay so i tried to reset the iac with no luck. It has a hard time starting but when it does it idles around 1500 for about 10 seconds and then the check engine light comes on and it dies what could this be?
edit: i think it must be vats I guess ill be patient for computer to get here. dang
Old Aug 24, 2009 | 04:38 PM
  #19
what code is it throwing?
Old Aug 24, 2009 | 04:40 PM
  #20
if it were vats it wouldn't run. assuming you are using the cars original starter signal wire it will turn the car over. if the vats were the problem you wouldn't be getting fuel and spark.
Old Aug 24, 2009 | 04:49 PM
  #21
I dont have any way of reading the code that i know of
Old Aug 24, 2009 | 05:01 PM
  #22
zzoomin's Avatar
Originally Posted by SupersportLS1
wow I never realized how much more room you have around the firewall and back of the engine compared to a 4th gen! clean lookin car, GL getting it running! I have a similair problem after cammin mine
Old Aug 24, 2009 | 10:41 PM
  #23
my car will not idle either but its cause its not tuned yet. but my cam is a 245/253 @ .050 yet i didn't see it written that the OP had swapped cams. its just a bolt on car? i have had failry large cam in a stock bottom end car that ran and idled fine on a stock tune. need to get a scanner from someone so we can see what the code is all about.
Old Aug 25, 2009 | 11:54 AM
  #24
The computer comes today so hopefully i can get it running good enough and take it to autozone to grab the code and ill post up what it is when i know. Hopefully it wont be there with a tune. And it has the original cam im pretty sure.
Old Aug 25, 2009 | 12:18 PM
  #25
ptown's Avatar
Im jealous of all the room you have in that engine bay. Nice looking ride.
Old Aug 25, 2009 | 07:10 PM
  #26
chevyowner02's Avatar
They are a blast to drive I have the same setup but with the cc503 and a 2800 stall.
Sitting Bull
56
Feb 15, 2005 10:59 AM
Sitting Bull
Sep 4, 2002 09:33 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
91Bird305
Aug 1, 2002 03:35 PM
